Jae 'Bird
- Dec 11, 2023
- Age
- 19
- Edmonton, Canada
- 1990 Ford Thunderbird Base with PEP 151A, 3.8L NA V-6
I've got an issue, I just finished re-doing the rear drum brakes as the old wheel cylinders blew. I also replaced the rearmost brake lines as they were rusted. I did everything correct, I think, and then it was time to bleed them, which is where the issues started. I of course started with the right rear as it was farthest from the master cylinder. I was bleeding it using the two person method and it was going ok but I was confused because I was getting micro-bubbles and they didn't seem to go away, I even tried using grease to "seal" up the threads to make sure it was closed up, I saw someone on the lube tube do it. Long story short I get about the same thing with all four wheels and when I started the car, the brake pedal was super mushy, I assume the micro bubbles are not ok to have right? I'm just making sure, and second, would air be coming in through the bleeder threads? is that possible. Lastly, would a power bleeder tool help to get rid of the micro bubbles that seem to be my issue? Thanks for the help in my predicament.
