Ericv8thunderbird
2nd Gear Poster
I installed a remote start in my daily, which is a '99 Mercury Sable. I've wired all the connections to the ignition wiring harness properly, But here's my issue, This car has the PATS system. I wired the D2D harness into the PATS system based off of the Taurus forums, I've doubled checked my connections and they all seem to be right, but when I plug the D2D harness in to the remote start module, The ignition (ACC) turns on and it won't start and I can't start it with the key, the only way to get the ignition off or to key start the car is unplugging the D2D from the module. What am I doing wrong?! I was under the impression that if you connected D2D you wouldn't need a key bypass. The remote start is an Avital 4115L.
