Seasoned Veteran Poster
We've all seen melted brake light housings and blackened light bulbs. Even with 912s, that keeps happening; meanwhile the brake light is dim.
Going to LED seems like a no-brainer, but there are various options. I did experiment with LED bulbs, but I didn't get the look and brightness I was looking for.
After playing with a few units at the junkyard, I settled for a Buick Lucerne brake light, which includes six upward shining LEDs, a complex reflector, and a clear lense. Price at the junkyard: $11.
Step 1
Obtain Buick Lucerne third brake light. Here is how to remove it from the car:
Step 2
Trim the unit. This is the great part: only minor cutting on each side is required, and the unit fits perfectly into the housing. It even clicks into place on top of the existing clips. (Ignore the beige leatherette on the second picture; that was a first attempt.)
I removed that leatherette and replaced it with a black foam sheet wrapped around a wood stick at the trailing edge for a nice round shape:
Step 3
Trim the old assembly. You only need the bottom portion, i.e., the part that screws to the shelf and clips to the housing. You also have to cut out an opening for the connector (which faces down).
Step 4
Cut off the old bulb sockets and attach the GM connector to the harness.
Step 5
Install the unit. You won't be able to screw it in. Instead, push a small zip tie through the hole from above, then secure with another zip tie end from the trunk.
Step 6
Assuming you have LEDs in the corners, as well, cruise control won't work at this point. You'll have to wire a bulb or resistor into the circuit. Caution: this may get hot, so choose a location accordingly. As always, follow these steps at your own risk; I'm not a professional!
Enjoy your new third brake light with a factory-ish look and excellent brightness:
