Seasoned Veteran Poster
This is not a major issue, but one I'd like to address before it gets worse.
The key moves in and out of the lock completely freely.
Turning the key, I can feel some mild binding. Instead of a smooth turn, I feel a sort of bid by bid turn. It's not excessively heavy, except for the turn to Start, which requires positive force. The spring return from Start to Run works fine.
Generally speaking, where is the cause for this kind of binding to be found? The lock and the switch are fairly easily accessible. The actuator/linkage on the other hand is pretty well hidden.
Can these components be taken apart and lubricated? With what? Where should I start?
