- North Ridgeville, OH
Overall
I am considering the purchase of a Mark VIII. What should I look for?
As always, having a trusted mechanic go over the vehicle is a good idea, especially one familiar with the Mark VIII. This is a rare bear, though, so you may look for these Mark VIII specific trouble spots.
- Leaking suspension. Check the vehicle after it's been sitting overnight. Is one corner or one end of the car completely down on the suspension?
- Transmission shudder. On light acceleration, does the transmission 'shudder', as though you were driving over 'rumble strips' when shifting from 3rd to 4th gear? If so, this may indicate a failing torque converter (worst case scenario) or transmission fluid breakdown.
- Brake vibration. The rotors are susceptible to warping, so this may be a 'bargaining chip'.
- Driveshaft vibration. Try taking the car on a smooth road and run it up to 75-80 mph. If there is vibration, this may also be a 'bargaining chip'. Read below in Transmission for more information.
- Startup rattle. The secondary cam tensioners are a known trouble spot. They will often rattle on the first few seconds after sitting overnight. Yet another 'bargaining chip'.
- If you have chrome wheels, look under the center cap for bubbling in the chrome finish. This seems to affect the cars exposed to salted winter roads.
- Check the rear swaybar, some members have reported cracked swaybars, due to corrosion in the hollow bar.
- Climate control blend door. The blend door actuator for the 97/98 model years is known to break and leave you without control over how hot/cold the air gets.
- The intake manifold runners (IMRCs) can get stuck due to lack of use over time. If the car falls flat on its face under hard acceleration over 3000 RPM, they may be stuck closed.
- The headlights on the 1st generation easily overheat and burn on the inside. This produces a creamy white or even brown appearance at the back of the reflector. This is not common on the 2nd generation or 1st generation LSC models as both were equipped with cooler HIDs.
What are the differences between the First Generation (93-96) and Second Generation (97-98) models?
The exterior was treated to a 'makeover' in 97, with a new 'power dome' hood, different grille, front and rear fenders, trunklid, lighting improvements by way of HIDs on all models, neon taillight, LED turn signals and puddle lamps in the side mirrors. The message center offers more functions, such as the side view mirrors pointing down when in reverse. The steering wheel now has tilt/telescope functions, and is tied to the seating presets on the door. The lumbar support became mechanical, instead of an inflatable system. The intake tube is different, the 'beauty cover' over the engine was revised, and the interior was revised. The 2nd Gen cars also feature coil-on-plug type ignition, and the retractable rear radio mast was replaced with one embedded in the rear glass. Traction control went from an optional low-speed (under 35 mph) system to a standard all-speed system. The JBL stereo with CD player became standard on the 2nd Gen cars, the optional cellular (analog and non-upgradeable to digital) phone was integrated into the stereo and message center. Heated seats were offered as an option, and there was a passive anti-theft system with transponder-coded keys added. A digital odometer replaced the analog one with a revised instrument cluster, and a redundant PRNDL indicator added to the cluster as well.
What are the differences between a LSC model and a Base model?
The Luxury Sport Coupe (LSC) edition had perforated leather seats, true dual exhaust, different gearing, LSC badging, and on the 95-96 models, included HID headlights. Some chrome trim was also painted body color on the 2nd Gen cars, such as the grille. Suspension tuning (anti-roll bars, shock valving) was firmer on the LSC models as well. The LSC models were rated by Ford at 290 HP versus 280 HP for the base model, and have a 3.27 vs. 3.07 rear end gear. The speed limiting function of the powertrain module kicks in at about 124 mph, versus 130 mph on the Base model (due to the higher gearing and drive shaft speed).
What interior changes were made to the Mark VIII in its production run?
Sometime during the 94 model year, the center console changed from flat black to a woodgrain finish. In 95, the dash was remodeled to house a double DIN radio, instead of the single DIN and a revised climate control unit with more durable controls was introduced. In 1996, a rear center armrest was added. The 1997-98 models received some interior finish changes to include more woodgrain, a further revised climate control unit, a revised instrument cluster, different seats offering optional heating elements, different door panels and center console with retractable dual cup holders, a fully electronic tilt/telescoping steering wheel and soft "theater" lighting.
What different models of Mark VIII are there?
In 93, 94, and the first part of 95, there was only one model. Many warranty registration cards had the LSC nomenclature, though it was not labelled as such. Beginning in 1995, the LSC package was an option. There were a few limited-edition model runs, such as the 1996 Diamond Anniversary edition and 1998 Collector's Edition, which you can read more about here.
