Seasoned Veteran Poster
Ugh.
Alright, some of you may remember that I had this code last spring. Bank 2, sensor 2, oxygen sensor rear/left.
Back then, all I did was reposition the connector which kept hitting the underbody. The code never came back (till now), and I eliminated an annoying rattle in the process.
Fast forward to today:
Looking at the connector, everything looks fine. I doubt I'll get away with any wire wiggling this time.
I went ahead and ordered two NTK sensors which are actually on sale for $35 a piece at Advance Auto Parts with free shipping. The wires on those sensors are stupidly long, though I guess front/right may need it.
Depending on my motivation when they get here, I'll either replace both fronts and move one front sensor back, or I'll only replace the offending sensor. I won't touch rear/right because that simply looks like a pain.
While I'm waiting for the sensors, I have two questions:
1.
How do I get out the sensor? It seems seized. WD-40? Heat?
2.
Why didn't this code come back sooner? I'm confused about that because this sensor always read differently than all the others. See below (top row):
This sensor also behaves differently when cold: it reads 1.275 V immediately after starting the cold engine; the three other sensors read 0 V until warmed up. Could that be some polarity issue?
And finally, the offending sensor looks different. Here it is:
Here are the other three.
Front/left:
Front/right:
Rear/right:
1.
2.
Front/left:
Front/right:
Rear/right:
