Wile E. Coyote
- Sep 21, 2023
- NJ
- 1996 Tbird LX, SVO blown 4.6 // 1990 Tbird SC Drift missile, OHV 5.0
What did you use for the climate control bulbs(ribbons?)? That illumination note is great!
Yeah, it's a neutral white LED ribbon wrapped once around the perimeter. I removed the clear diffuser inside as well.What did you use for the climate control bulbs(ribbons?)? That illumination note is great!
If you take the OT button out you can scrape away the green film on the inside to make it light up white too, I converted one to blue once for a short lived experiment when I had 97 SHO gauges(also blue), same thing scraped it clear, just painted in blue after
I bought a 25' spool of ribbon for the instrument cluster after the strip Scott H sent me with his gauges wasn't quite bright enough and left behind the notorious dark spot by the trip odometer reset pin. I double-wrapped the new ribbon around the cluster and after seeing those results, I knew the ribbon was going to be the way to go for the SATC as well. A pair of 360° LED bulbs, especially with the quality and brightness of the ones available in the mid-2010s, would have had nothing on this.
In hindsight, I should have scraped the green behind the OT button. I just didn't think to do it at the time. I could take another crack at it one day, but it would be a very low priority.
Those aren't LEDs. That's a proper HID retrofit that was professionally assembled and aligned.I do not like LED lights pointed at me. Sometimes I have to cover my rear view mirror. You're aiming them down and thats appreciated. And that applies building and street lights as well
For a moment, I forgot that those are 74 bulbs that go in the SATC, not 194s. I think that makes a ribbon by far the best option for even lighting. Even the best 74s today probably won't do that well there.Ah ribbon is what I figured, I had zero luck with the miniature LEDs there, they barely even fit and the light was very uneven. The cluster with the stock gauge faces and their printed on diffusers do alright with LED 360 bulbs but not there, I just put the incandescent bulbs back in the climate control. I'll give this a go, also not a high priority but your pics are very inspiring!
This image is breaking my brain. What's happening here and why is it not a photo of a floating seat belt guide?Having nothing is fine, but as long as I can remember, an intricate seat belt design always conveyed luxury to me. As a kid, my best friend's grandfather owned a Mercedes 420 SEC; that was the first car with automatic seat belt presenters. Such decadence.
No sane MN12 owner wants automatic seat belt mechanisms if they've experienced a pre-refresh model.
We had a 1989 Maxima with automatic belts. Hard pass. Never again. Even the reliable ones that our Maxima had would drive me insane.Okay, I zoomed in on the photo and I see what's going on now.
Martin, check this thread out: https://www.mustang6g.com/forums/threads/seatbelt-guides.115173/Just playing with junkyard parts. Went back to stock though; it requires a longer bolt, so the whole assembly sticks out too much for my liking.
I still think that a 2-door coupé should be equipped with some sort of seat belt guide or mechanism. I know, we have the lower anchor sleeve which makes it easier to grab the belt from the bottom.
I'm talking more esthetically though; functional advantages are more of a bonus. Some may remember that I experimented with a Challenger belt guide:
I never really loved that though.
GM says they are discontinued and sold out. Fleabay has some knockoffs. Going to order a set and try them.@Derphound01 , those are Chevy Cobalt units. I haven't tried those.
My '89 has the auto belts (it was well equipped for a base model) and I like them.Okay, I zoomed in on the photo and I see what's going on now.
They all did. US required passive restraints back then. Airbags, automatic belts, or the Audi system I posted above all met the standard.My '89 has the auto belts (it was well equipped for a base model) and I like them.
Took these ones yesterday. This shit infuriates me!
Like, October hasn't even started yet and these shits are already out like it's the height of the season.
