Thunderstruck95
My 95 Thunderbird has factory ABS and I want to remove the system to lose weight and simplify things. My master cylinder has two lines coming off it and a hose bringing fluid down to the pump.
Can I simply put T's on both lines and find a suitable plug for the fluid line? (I would plan on using the factory pressure regulators/ restrictors that are behind the drivers tire and run to the back)
Is there a pressure switch anywhere that is needed to run taillights or signal the EEC?
