Grog6
Moderator
- Harriman, TN
To change the transmission fluid, I recommend dropping the pan on the bottom; this gives you the opportunity to see how much wear has happened, either since the last change, or ever.
You will need: 6 to 12 quarts of Mercon V transmission fluid A filter for sameyear trans. How much fluid depends on how far you go.
You will only use 12 quarts if you do the pan, tc, and drop the vb. If you do the jmod, you will need 12.
Optional parts: Dorman pan with drain plug
New style 1-2 accumulator
Brown 1-2 spring(very optional, barks 1-2)
An oil drain pan at the front edge of the trans pan, pull the 4 front bolts. loosen all bolts on the pan 2 turns. Starting at the front of the pan start removing bolts in pairs, left side right side, alternating sides. Each time you pull a pair out, give all the other bolts one turn At some point pan will droop down, dumping mercon (Hopefully) into the pan. Good luck, this is the 'mercon shower' these are famed for.
Keep going until the pan drops.
Set the pan aside for now.
Pull the filter straight down using both hands. Make sure the orange rubber seal is not in the filter bore. There are pix in the Jmod article. Inspect the condition of the wires, looking for missing insulation, etc.
Inspect the pan: the black stuff is friction and metal worn off the plates in the trans. The thing with black 'hair' is a magnet there to collect it. carefully pull it off the pan, and clean it off with a clean lint free rag. Wipe the pan out.
If there's a white 'top' looking thing, it's the "Secret magic mystery prize!" It's a seal the factory used, and it means the trans has never had the filter changed.
Pull off the rubber cover below the torque converter, and turn the engine until you see the drain plug.
Drain it into the pan, this is about 4 quarts of fluid.
Put the drain plug back in.
This is the point you do the Jmod, if you're doing that, or change the 1-2 accumulator. Put in the filter, noting the pickup and pan dimple. Spending the $20 for the dorman pan means you get to skip the droopy part. If you get the dorman pan, swap your magnet over.
Put the clean pan back in, making sure the flange didn't bend during the drooping part. a hammer and the garage floor will flatten it out if it did.
Reuse the original gasket, you don't need sealer.
Torque all bolts to 20ft-lbs; don't overtighten.
Verify all bolts; add 4 qts of fluid, and start the engine. add 1 quart, run the trans thru the gears with the shifter, while letting it idle in neutral.
Check fluid level
add 1/2 qt at a time until it reaches the full cold line.
Drive it around the block, let it shift thru the gears.
From a redlight, shift it manually thru the gears;
Recheck the fluid level, it should now be at "full warm".
You're done. I write it down in the car's logbook,with the mileage, and tape the receipts in it.
Check fluid level
