Seasoned Veteran Poster
Which DRL color do you prefer?
Note: This thread is not intended to discuss the pros & cons of DRLs in general.
Current Situation
What I'm Considering Instead
Some Background Info
I like Sylvania Zevos (and already have an extra pair of amber ones), so I don't want to use any kind of switchback LEDs.
I really like the added inboard turn signal functionality because I think the outboard turn signal isn't as visible when you're at a slight angle toward oncoming traffic.
The main question is: how do we feel about amber DRLs? They're somewhat common, though not nearly as common as white ones. Is too much amber a distraction from actual turn signals?
Current Situation
- outboard lights (corners) - amber:
- bright: turn signals
- dim: parking lights and sidemarkers
- inboard lights (next to grille) - white:
- bright: DRLs
- on with ignition on
- off with low beams on
- inboard lights (next to grille) - amber:
- bright: DRLs and turn signals
- Ignition off: hazards work as normal, 4 total in the front
- Ignition on: 4 bright amber DRLs
- Turn signals in use: the 2 DRLs on the respective side flash off (alternating with rear turn signal); the 2 DRLs on the respective other side stay lit
- Low beams in use: turn signals work normally, 2 per side
