- North Ridgeville, OH
For you junkyard crawlers out there, please keep an eye out for a few things I could use! None of these are critical, but I'm OCD, so......
- 97-98 driver's side heated mirror glass
No need to spend the time/effort trying to get the whole mirror housing off the door. The mirror glass just "pops off" the motorized base. Push the inside of the mirror in so the left side protrudes from the housing a little, then just pry it away from the housing. It will pop right off with a little effort. See the attached image for details.
Mine was originally equipped with a heated and auto-dimming mirror but the PO swapped it out for a non-heated, non-dimming mirror (presumably because the auto-dim fluid got dark), and I could really use the defrost!
Another option I am willing to consider is a trade+cash for my non-dimming, non-heated mirror if anyone who is driving one of these doesn't need the heat function. - 97-98 driver's side mirror puddle lamp assembly
I cut mine open to try and fix intermittent LEDs for the turn signal, but the circuit board was pretty damaged and the LEDs were rusting away. - 98 Charcoal Gray steering wheel
Mine is in decent shape, but if there's a nicer example out there, I wouldn't mind having one. This is a 98 specific color; in 97 they were black. If you happen across one of the super-rare collector's edition Marks, I would be interested in seeing how that might look. Who knows.... - 98 Charcoal Gray driver's seat trim
Mine has a couple busted mounts that no amount of epoxy has been able to (consistently) fix. - Spare HID bulb
Mine work fine, but if you happen across one I'd feel better about having a spare.
