- North Ridgeville, OH
Send your oil out for analysis if you want to be sure.
I think you'd be able to smell it. Plus oil will soak in. Just not sure how fast. Gas would soak in quicker.
I always taste it if I'm not sure on smell. If it's a bit sweet there's antifreeze in it. Gas tastes like....gas
How has your fuel economy been? Overall power?
Thanks for the advice, it worked out just fine. I bought a small jar of airbrush paint reducer off Amazon for $7. Put a bit of it into the touchup paint jars, and it mixed in with no issues.I would use reducer rather than paint thinner.
Definitely doable. Helps to have a friend.So is it possible to remove the headliner in one piece through one of the doors? Headliner acrobatics?
Done it several times. Need to do another one soon.I'd have to say Yes to both your questions. And i'm Sure Gordo has done it before.
I've just used headliner material in the stock color. But you could use the suede material if you like. I've seen it before in custom interiors.I won't do it any time soon as the damage is minimal at this point. But I'm curious: do you all just replace the headliner cloth with the same material/color, or do you go with anything different?
I think I would go the faux suede route as I've had positive experiences with that material. I'm also thinking about going darker, matching the dash.
