- North Ridgeville, OH
Grog6 said:You can set the paint without an oven; you hang them up vertically and hit the bottom with a torch until it stops smoking or the glass melts.
General Zod said:Glad to see you got them on and see the gains !
Draetech09 said:Good to see someone finally put them to work. I knew they were going to smoke heavily also lol.
Now that the bird is nesting for the winter, there are some odds-and-ends that need to be tended to.
The #5 primary is rubbing against the frame rail/shock tower and transmitting quite a bit of extra engine NVH into the entire car. There's a little extra room on the passenger side so I need to find a way to shim the engine slightly to the passenger side. I was thinking I'd loosen up the driver's motor mount and add a couple washers to raise that side of the engine slightly, which I'm thinking (theoretically) will rotate the headers up and away from the body. Unless someone here has a better suggestion...
I also need to deal with the rat's nest of coolant hoses at the back (courtesy the "crack pipe" coolant mod plumbing plus the CELO sensor) and replace the valve cover gaskets, so it sounds like the intake is coming off as well.
