JacobM03
1992 tbird 5.0
I am in the middle of doing an ABS delete and I am tearing out the whole system. While in the trunk I took off the ABS controller and found a black box that apparently is the power steering module.
Is this module a part of the ABS system and can I remove it too? It runs in the same harness. If not what does that module even do?
Also how do I remove the hanging box these modules were in? I popped out one side but the other side is holding on with some sort of pins.
Thanks in advance.
Thanks in advance.
